Ip touch phone directory
electreng
Post by electreng »
hey all fo you
plz any body have an idea how can i configure my IP touch 4038 with text messiging and open the directory of my PBX as the digital handsets >>>>>
stefan
Re: Ip touch phone directory
Post by stefan »
go to USER and check the "dial by name & mini mail" option. (it enables the integrated keyboard)
check system docs ! (top right hand corner, RED flashing thing on the page !)
you can type..... so why not try reading for a change .....
Er..Stefan, that answer is valid of an OXE, not for an OXO...anyways documentation has been posted by some guy on an external link. Will ask Frank to include it on our DB
stefan
Post by stefan »
oeps...... and I have no OXO knowledge..... sorry :roll:
steve
Post by steve »
It should be work by default.
Except if U have changed the set. Please check the valid type of the set in the OMC software.
If U can see a red set type in the Temporary Type field in the Subscribers/Details, then unplug the set, change the the terminal type to UA Access and plug it again.
Return to “Configuration”
