Hello to all,
I`m having a problem to configure the Tales IP Touch Security Module.
I understood almost everything in the configuration, the only problem is that I have to load a psk file, and I don't know where i can find this file.
If somebody knows how to help me please give me a light.
Thank you very much!
PSK file
Gedeon
Re: PSK file
You must use the application on the CD-Rom provided with the SSM.
You have a documentation file on this CD.
G
G
- frank
Re: PSK file
Those files are generated automatically by using the Security Center. It is in the system documentation.
Re: PSK file
Does anyone know what the maximum size of the usb drive is about? 4 GB drives do not work, I still have some 1 GB for that
- frank
Re: PSK file
I did not think the size matter. I though as long as it's an external drive.
I tried on a 1GB, and it works.
Re: PSK file
I use Security Center 1.1.00 and even empty 4GB sticks are declared to have "not enough space to store the psk-file"........
