Alcatel OXE WLAN configuration
jopatini
I need a help trying to configure an OXE system with an SVP server and two IP touch 310 sets.
I declare in the set the IP @ of the SVP and the CS, but when I turn on the set it shown "no SVP response" indicating the SVP IP@.
What is the meaning of the parameter "First/Last Alias IP @" in the SVP ?
Should I declare in OXE any parameter concerning the SVP ?
jopatini
Re: Alcatel OXE WLAN configuration
Yes and I have spend a good amount of time on it. The configuration of SVP is very simple, although I do not understand this Alias IP @.
Another thing is that when I check the access point log files, I see that OXE CPU is trying to reach the access point, but the password is wrong. However the access point password is introduced only in the IP sets, not in the CS or the SVP server
mysticalself_DUP
What is the vesion of the SVP server and OXE?
jopatini
OXE releae is 8.0 and SVP type is 010
mysticalself wrote:What is the vesion of the SVP server and OXE?
jopatini
jopatini wrote:OXE releae is 8.0 and SVP type is 010
OXE version is G1.503.12a
SVP H/W version is 33/02, it's factory page is 213.001
kike
It is necesary to declare the IP alias address in SVP, one for each MIPT. MIPT phones use their own IP addresses, but between SVP and OXE are these IP alias addresses used: OXE "see" the MIPT in these addresses. First and last IP alias define the range used, you will need only two.
Read about "pseudoNAT" feature in SVP.
jopatini
Everything is under static conf:kike wrote:It is necesary to declare the IP alias address in SVP, one for each MIPT. MIPT phones use their own IP addresses, but between SVP and OXE are these IP alias addresses used: OXE "see" the MIPT in these addresses. First and last IP alias define the range used, you will need only two.
- SVT 172.30.5.218
- Alias address in SVP: 172.30.5.223 (first) and 172.30.5.224 (last)
- MIPT 172.30.5.219 and 172.30.5.220 (I have two sets)
- CS 172.30.5.216 and
- GD 172.30.5.217
- Access Point (PROXYM): 172.30.5.225
Shound I configure something special (besides the information in the doc for R8.0) concerning the SVP ?
Thank
bouncer_ie
Jopatini did you get this resolved? I have to install SVP for the first time soon so any tips are appreciated
spring
Anybody know how to read the alias and private IP Addresses assigned on the MIPT phone?
Can it be done on OXE system or on SVP Server?
