Greeting Messages using 4035
Mussoa82
Post by Mussoa82 »
Hi everybody, I have a question : is it possible to have a greeting message in parallel mode using 4035 as a normal user instead as 4035 used as attendant?
thanks!!!
Re: Greeting Messages using 4035
Use incoming greeting guide with routing to the set.
Or if general message on system, delete tone for ringback on ext lines with your message.
Regards.
Return to “Attendant”
