GD password
Urri
GD password
Post by Urri »
Hi!
The su password on GD board is lost. As a result I can't access the mgconfig command. How I can reset su password on GD board?
kleva
Re: GD password
Post by kleva »
Sorry, I don't know of any easy way to get back the root password...
Take out GD...Take HDD off GD... Take to nearest Linux/Unix Boffin to mount as another drive... They should be able to restore your access with methods that I wont post here...
You will obviously have to take this GD offline for the duration of that, so either have a second GD configured and ready or take client offline till done...
knightr1der
Re: GD password
Post by knightr1der »
why not force a binary reload using <ctrl> i blah blah blah?
Re: GD password
because blah blah x 2 = ouch ouch and then cames the damn damn.
knightr1der
Re: GD password
cavagnaro wrote:because blah blah x 2 = ouch ouch and then cames the damn damn.
I agree - maybe I should have added "get a oxe trained tech - not a genesys trained one and do a binary reload" then there will be no "ouch" or "damn" - just bliss and a calm serenity...
Re: GD password
:lol: :lol:
ps: dude answer my last PM...please...the docs name...
zanex
Re: GD password
Post by zanex »
kleva wrote:Take HDD off GD
berty_DUP
Re: GD password
Post by berty_DUP »
Yep - you need to remove the invisible hard drive Zanex.................!! :lol:
As has been said, best off flashing the board via PC Installer + starting again
Eliott_DUP
Re: GD password
Post by Eliott_DUP »
berty wrote:Yep - you need to remove the invisible hard drive Zanex.................!! :lol:
:lol:
alex
Re: GD password
Post by alex »
:lol:
:lol:
With invisible screwdriver!
:lol:
Return to “ON SITE TROUBLES”
