New PBX moving from Nortel platform
sgatkinson
Post by sgatkinson »
We will shortly be getting a new Omni PCX moving from a Nortel Option 61c. Has anyone done this? What are some of the things I should be looking at as to differences or other gotchas.
Steve
Hi !
I did it...
You just have to know by heart your nortel configuration, and install from scratch your OmniPCX.. It should be easy, and I would recommend to do the cutover on a Friday night :-) Also, have both systems running for a little while so you know that everything is ok ..
F.
Return to “GENERAL”
