any idea?
kenzo_DUP
any idea?
Post by kenzo_DUP »
INCIDENT NUMBER: 2252
OBJECT CLASS: Dhs3x_node
EVENT TYPE: ProcessingErrorAlarm (10)
PROBABLE CAUSE: Unknown (0)
SEVERITY: Major
"AP1: Pb P2, tty P3, st = P4 (P5)."
"P1 : Name of the application in which the problem has occurred"
"P2 : Name of the CHORUS/MIX primitive which has failed (ioctl, fopen,"
" freopen, ...)"
"P3 : Label of the channel on which the problem has occurred : stdin,"
" stdout, ..."
"P4 : Return code of P2 primitive (the labels of the return codes are also found"
" in the source files of CHORUS/MIX. For each label, the explanation of the"
" fault occurred is dealt with in the CHORUS/MIX man(manual)"
"P5 : input/output tty used by the P1 application during the current execution"
" (ttyxx, sccxx,spbxx, io2ttyxx, ..., ? if unknown)"
"Error when a primitive giving access to a tty is executed (ioctl, fopen, fread,"
"Probable cause : Software program error"
"Severity : Major"
"Type : Processing error alarm"
"fwrite, ...)Object class :Dhs3x_node"
"A problem has occurred during an operation concerning the P3 tty."
"if P1 = APL_HOTELMENU or APL_NAUDIT : the system generates an incident and"
" then keeps on progressing."
"Try to understand the problem which has occurred using P4 and write an"
"observation slip as complete as possible.";
hobbls
Post by hobbls »
Sorry you must shown the complet incident ! not only the number !
kenzo_DUP
Post by kenzo_DUP »
go
(102)ms4400a> incvisu|grep 2252go 5 2
29/10/05 03:54:00 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 22 (?).
29/10/05 03:54:00 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:54:00 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:54:11 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:54:11 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:54:18 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:54:18 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:55:11 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:55:11 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:55:24 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:55:24 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:55:24 001002M|--/--/-/---|=2:2252x095=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:55:42 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:55:42 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:55:43 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:55:43 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:56:34 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:56:34 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:56:35 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:57:11 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:57:11 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:57:41 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:57:41 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:58:25 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:58:25 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:58:41 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:58:41 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:59:07 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:59:07 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:59:07 001002M|--/--/-/---|=2:2252x140=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:59:11 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:59:11 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:59:12 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:59:12 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:59:29 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:59:29 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:59:41 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:59:41 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:59:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:37:43 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 03:59:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:00:41 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:00:41 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:00:51 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:00:51 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:00:54 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:00:54 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:02:17 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:02:17 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:03:21 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:03:21 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:03:41 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:03:41 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:03:42 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:03:42 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:04:41 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:04:41 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:05:11 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:05:11 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:05:41 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:05:41 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:06:08 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:06:08 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:07:11 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:07:11 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:07:34 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:07:34 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:07:41 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:07:41 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:08:24 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:08:24 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:09:14 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:09:14 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:10:04 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:10:04 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:10:41 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:10:41 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:10:55 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:10:55 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:11:41 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:11:41 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:11:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:11:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:12:11 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:12:11 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:12:35 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:12:35 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:12:41 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:12:41 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:13:25 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:13:25 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:13:41 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:13:41 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:14:11 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:14:11 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:14:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:14:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:14:41 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:14:41 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:15:29 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:15:29 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:16:12 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:16:12 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:16:19 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:16:19 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:16:42 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:16:42 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:17:09 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:17:09 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:17:12 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:17:12 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:17:59 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:17:59 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:18:23 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:18:23 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:19:12 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:19:12 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:19:42 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:19:42 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:20:12 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:20:12 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:21:12 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:21:12 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:21:42 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:21:42 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:24:00 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:24:00 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:25:14 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:25:14 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:26:14 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:26:14 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:26:44 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:26:44 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:27:22 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:27:22 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:27:44 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:27:44 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:29:14 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:29:14 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:29:44 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:29:44 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:30:44 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:30:44 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:30:56 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:30:56 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:31:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:31:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:32:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:32:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:35:16 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:35:17 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:36:35 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:36:35 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:37:09 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:37:09 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:38:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:38:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:39:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:39:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:39:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:39:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:40:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:40:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:40:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:40:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:41:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:41:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:42:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:42:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:42:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:42:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:43:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:43:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:45:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:45:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:47:50 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:47:50 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:50:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:50:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:51:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:51:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:53:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:53:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:54:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:54:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:55:11 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:55:11 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:56:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:56:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:56:35 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:56:35 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:56:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:56:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:57:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:57:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:57:25 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:57:25 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:57:27 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:57:27 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:58:42 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:58:42 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:59:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 04:59:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:00:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:00:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:02:06 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:02:06 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:02:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:02:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:02:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:02:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:02:56 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:02:56 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:04:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:04:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:05:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:05:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:07:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:07:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:08:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:08:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:09:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:09:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:09:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:09:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:10:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:10:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:10:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:10:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:10:57 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:10:57 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:11:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:11:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:12:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:12:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:13:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:13:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:15:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:15:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:17:02 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:17:02 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:19:19 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:19:19 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:19:23 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:19:24 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:20:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:20:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:20:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:20:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:21:15 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:21:15 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:21:46 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:21:46 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:22:59 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:22:59 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:24:46 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:24:46 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:25:16 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:25:16 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:25:46 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:25:46 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:26:46 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:26:46 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:28:10 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:28:10 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:28:16 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:28:16 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:30:04 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:30:04 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:30:16 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:30:16 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:30:40 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:30:40 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:30:46 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:30:46 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:31:16 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:31:16 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:31:46 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:31:46 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:32:16 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:32:16 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:33:16 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:33:16 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:33:46 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:33:46 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:34:06 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:34:06 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:34:16 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:34:16 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:34:46 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:34:46 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:43:01 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:43:01 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:44:09 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:44:09 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:44:20 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:44:20 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:46:39 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:46:39 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:47:39 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:47:39 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:48:09 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:48:09 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:49:09 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:49:09 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:49:39 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:49:39 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:50:09 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:50:09 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:53:39 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:53:39 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:54:39 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:54:39 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:56:09 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:56:09 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:58:09 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:58:09 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:59:11 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 05:59:11 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:00:01 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:00:01 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:03:09 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:03:09 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:03:39 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:03:39 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:04:09 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:04:09 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:05:39 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:05:39 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:06:09 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:06:09 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:07:39 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:07:39 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:09:40 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:09:40 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:10:40 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:10:40 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:12:10 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:12:10 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:13:00 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:13:00 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:13:10 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:13:10 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:13:50 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:13:50 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:14:40 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:14:40 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:15:10 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:15:10 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:15:30 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:15:30 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:16:10 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:16:10 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:16:40 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:16:40 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:17:10 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:17:10 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:38:13 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:17:40 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:17:40 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:18:10 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:18:10 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:18:40 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:18:40 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:18:59 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:18:59 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:21:40 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:21:40 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:22:10 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:22:10 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:22:40 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:22:40 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:23:10 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:23:10 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:23:40 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:23:40 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:24:10 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:24:10 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:25:10 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:25:10 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:25:37 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:25:37 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:25:40 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:25:40 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:26:40 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:26:40 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:27:12 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:27:12 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:27:40 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:27:40 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:29:10 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:29:10 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
29/10/05 06:29:40 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 22:33:04 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 22:33:05 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 22:33:05 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 22:33:51 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 22:33:51 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 22:42:30 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 22:42:30 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 22:43:00 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 22:43:00 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 23:15:24 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 23:15:24 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 23:18:52 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 23:18:52 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 23:36:46 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 23:36:46 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 23:37:46 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 23:37:46 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 23:37:46 001002M|--/--/-/---|=2:2252x053=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 23:47:36 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
30/10/05 23:47:36 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 00:02:43 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 00:02:43 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 00:13:28 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 00:13:28 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 00:37:26 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 00:37:26 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 00:37:26 001002M|--/--/-/---|=2:2252x095=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 00:47:46 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 00:47:46 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 01:47:51 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 01:47:51 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 02:22:23 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 02:22:23 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 02:47:57 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 02:47:57 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 03:48:02 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 03:48:02 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 04:04:46 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 04:04:46 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 04:48:07 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 04:48:07 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 05:48:13 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 05:48:13 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 06:36:08 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 06:36:08 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 06:48:22 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 06:48:22 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 07:30:53 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 07:30:53 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 07:31:13 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 07:31:13 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 07:33:14 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 07:33:14 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 07:35:43 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 07:35:43 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 07:41:08 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 07:41:08 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 07:48:28 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 07:48:28 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 08:03:51 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 08:03:51 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 08:04:23 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 08:04:23 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 08:05:04 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 08:05:04 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 08:21:37 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 08:21:37 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 08:41:56 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 08:41:56 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 08:48:33 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 08:48:33 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:00:24 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:00:24 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:17:02 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:17:02 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:22:14 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:22:14 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:39:07 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:39:07 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:41:59 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:41:59 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:47:13 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:47:13 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:48:39 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:48:39 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:52:56 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:52:56 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:58:05 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 09:58:05 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:00:58 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:00:58 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:01:09 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:01:09 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:04:34 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:04:34 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:08:25 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:08:25 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:15:08 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:15:08 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:18:33 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:18:33 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:23:59 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:23:59 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:24:04 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:24:04 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:24:14 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:24:14 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:37:13 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
(102)ms4400a>
(102)ms4400a> incinfo GEA
Incident number (q to quit):2252
SEVERITY: Major
" freopen, ...)"
" stdout, ..."
"Severity : Major"
Incident number (q to quit):q
(102)ms4400a> exit31/10/05 10:39:13 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
logout
Linux Mandrake for eMediate release 7.2 (Odyssey) for i486
Kernel 2.4.1-ll-dhs3 on an i686 / ttyS0
ms4400a login:
ms4400a login: mtcl
Password:
Last login: Mon Oct 31 10:23:55 on ttyS0
Alcatel OmniPCX Enterprise
standard installation last performed: 12-Oct-2005 10:05:03
# The role of the CPU is MAIN
Application software identity
31/10/05 10:39:43 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
R6.1-f2.500-6-n-sg-c7
Business identification: R6.1
Release:
DELIVERY f2.500
Patch identification: 6
Dynamic patch identification: n
Country: sg
Cpu: c7
ACD VERSION
release : 6
bug_fixing : 1
protocol_id : 90
version_dy_hr_stat : 11
31/10/05 10:39:45 001002M|--/--/-/---|=2:2252x999=A15: Pb read, tty stdin, st = 5 (?).
31/10/05 10:39:45 001002M|--/--/-/---|=3:1125=external alarm : "mtcl login"
31/10/05 10:39:45 001002M|--/--/-/---|=2:2252=A15: Pb read, tty stdin, st = 5 (?).
(102)ms4400a>
(102)ms4400a> config 3
| 3 | 0 | UA32 |---------- | REG NOT INIT | BAD PCMS CODE |
| 3 | 2 | UA32 |---------- | REG NOT INIT | BAD PCMS CODE |
| 3 | 4 | UA32 |---------- | REG NOT INIT | BAD PCMS CODE |
| 3 | 6 | INTOF_B |---------- | IN SERVICE | 3BA53118AABB04 |
| 3 | 8 | UA32 |---------- | REG NOT INIT | BAD PCMS CODE |
| 3 | 9 | UA32 |---------- | REG NOT INIT | BAD PCMS CODE |
| 3 | 11 | UA32 |---------- | REG NOT INIT | BAD PCMS CODE |
| 3 | 13 | GPA |---------- | IN SERVICE | 3BA53097AAAA03 |
| 3 | 15 | INTOF_A |---------- | IN SERVICE | 3BA53118AABB04 |
| 3 | 17 | INTOF_A |---------- | IN SERVICE | 3BA53118AABB04 |
| 3 | 19 | NDDI |---------- | IN SERVICE | 3BA53095AWBB02 |
| 3 | 20 | INTOF_B |---------- | IN SERVICE | 3BA53118AABB04 |
| 3 | 22 | INTOF_A |---------- | IN SERVICE | 3BA53118AABB04 |
| 3 | 24 | INTOF_A |---------- | IN SERVICE | 3BA53118AABB04 |
| 3 | 26 | BPRA2 |---------- | IN SERVICE | 3BA23074ABAC03 |
| 3 | 27 | NPRAE |---------- | REG NOT INIT | BAD PCMS CODE |
--- Inter Crystal Topology ---
| CR | CPL Type Role Free/Tot Role Type CPL | CR |
| 03 | 06 -INTOF_B (MAIN ) --- 78/78 --- ( INT_A) INTOF_A - 00 | 00 |
| 03 | 20 -INTOF_B (STANDBY) === 76/78 === ( INT_A) INTOF_A - 22 | 00 |
| 03 | 15 -INTOF_A (INT_A ) === 78/78 === ( MAIN) INTOF_B - 01 | 06 |
| 03 | 24 -INTOF_A (INT_A ) === 78/78 === ( MAIN) INTOF_B - 01 | 07 |
| 03 | 17 -INTOF_A (INT_A ) === 78/78 === ( MAIN) INTOF_B - 01 | 10 |
| 03 | 22 -INTOF_A (INT_A ) === 77/78 === ( MAIN) INTOF_B - 01 | 12 |
(102)ms4400a> exit
logout
ms4400a login:
Connection closed
RMA>exit
Goodbye.
What is you problem?
hobbls
Post by hobbls »
Do you use any Application with your pbx ?
Return to “GENERAL”
