real time output of account data
stekmtiki
Post by stekmtiki »
hi
i am having problem getting real time accounting data output on v24 port.
please see attached programming done.
i am connecting to cbrma box on com C.
i appreciate your input in the matter.
4.3 BSD UNIX (xa000000) (ttyp1)
login: mtcl
Password:
# The role of the CPU is MAIN
Application software identity
R4.2-d2.304-4-h-ng-c6s2
Business identification: R4.2
Release:
DELIVERY d2.304
Patch identification: 4
Dynamic patch identification: h
Country: ng
Cpu: c6s2
ACD VERSION
release : 4
bug_fixing : 4
protocol_id : 75
version_dy_hr_stat : 11
Consult/Modify: Accounting-----------------------
Node Number (reserved) : 1
Instance (reserved) : 1
Internal Accounting + YES
Monitoring + NO
Financial Report + NO
Tickets Storage + NO
Files for External Accounting + NO
Real Time Tickets Output + V24
Company Billing Rating
Unit Price : 0.74
VAT (In %) : 20.60
Nb Of Digits In Decimal Part : 2
Currency : FF
Dialling Format : 10
Phone set
Displayed Value + Cost
Front Office Computer Parameters
Nb of Last Masked Called Digits
Usual Calls : 0
Project calls : 0
Personal Calls : 0
Local Local Calls : 0
Local Network Calls : 0
Local Transit Calls : 0
Filter
[ Add ] [ Remove ] [ Next ] [Previous]
Filter + Public Local Outgoing Calls
Hotel/Hospital Billing Rating
First units price : 0.740000
Number Of 1st Units : 1
2nd Units Price : 1.000000
Number Of Second Units : 5
Last Units Prices : 2.000000
Printout Buffer Parameters
% Before 1st Alarm : 60
% Before 2nd Alarm : 85
Real Time Tick.Outp.Parameters
Real Time Printer V24 + /dev/scc0a (2)
Printing format + Extended
PIN (Personal Ident.No.) + Not Masked
Lines Per Page : 65
Line spacing : 0
Usual Calls : 0
Project calls : 0
Personal Calls : 0
Filter
Consult/Modify: V24 Port---------------------------------
Port + /dev/scc0a (2)
V24 No. : 2
RTS/CTS protocol + False
Dynamic + False
TA Directory No. : --------
Speed + 9600 b/s
Parity + None
Data bits + 8 bits
Stop Bit + 1 Bit
Terminal Type + VT100
V24 Application + Other Application
Parameters : without
Port Dir.No (Static) : --------
First of all, did you try to plug a computer on your C port, with hyperterm, to see if you have any tickets going out on the console ?
I don't remember by heart, but I am not sure that /dev/scc0a is port C.
I am not saying it's wrong, I just don t remember. I will try to check it out later and let you know..
charan
Post by charan »
You need to enable
FILES FOR EXTERNAL ACCOUNTING :YES
make this modification and see if it works
amumar12
Post by amumar12 »
How is your parameter 'real time ticket' output under mgr- applications-accouting.
You also have to check the filters for the different fields to be output under the same menu.
charan
Post by charan »
hi
Go to mgr-appilicatons-accounting-in that you find this parameter
Return to “GENERAL”
