regarding vlan on oxe
kenzo_DUP
Post by kenzo_DUP »
would like to segment our voice and data into different segment by means of VLAN. As such, please take this into consideration in preparing a IP phone network design. Please provide us the necessary information (e.g. what is the IP address range you required, number of VLAN segment, etc) required in order for our vendor to prepare the switch. The switch which we will be using is the Cisco Catalyst 4506 with 2x 48-ports (10/100/1000) PoE modules and 1x 48 ports (10/100/1000) normal Ethernet module.
anyone can help on this thanks
Your vendor should provide you the informations needed..
kenzo_DUP
Post by kenzo_DUP »
on my site what i need to configure for VLAN
Your cisco catalyst is a serie 4500.
Serie 4500 is vlan capable (IEEE 802.1Q).
You just need a CCNA to configure it :-)
kenzo_DUP
Post by kenzo_DUP »
ok thank.
On the mgr oxe side do i need to configure anything thanks
You will need to configure the VLan on the IP phones....... :roll:
kenzo_DUP
Post by kenzo_DUP »
ok will do how about the DHCP side at mgr........
it so simple to set..... :lol:
If you go DHCP, you just have to manage the DHCP vlan, that's all
kenzo_DUP
Post by kenzo_DUP »
mean to say the vendor need to give me the range IP Address......public
No, no public address !
The IP phone should be in a private network.
Choose something like 192.168.x.x
Return to “GENERAL”
