Locking problem without pasword
baban_ele_DUP
Post by baban_ele_DUP »
I am facing one problem at user site
when user dial 75(which is default lock code) the extn becomes lock and it opens with only lockcode followed by password. It is comming after Rel 5.0 softwareOMC installation.
et
Re: Locking problem without pasword
Post by et »
What's the problem is? It's a normal behaviour.
Ganesh
Post by Ganesh »
after rel 5 it work but only in some relese and only in analog extentions.
Ganesh wrote:after rel 5 it work but only in some relese and only in analog extentions.
I doubt that a feature as simple as that has problems from a sw release to another.
I never observed that.
Which sw releases supported set locking and which ones not?
Return to “Configuration”
