Redial / DTMF
Redial / DTMF
Hi all,
Is it possible to have a key for REDIAL on the attendant console (4035T) ?
Also, is it possible to allow the attendant to send DTMF codes on an outgoing call ?
Thanks !
gundam
Post by gundam »
For DTMF and Attentdnet Consol you will have to access the represent key/function and then the DTMF option will appear (for out going calls).
Hey Gundam,
Thank you for your answer.. Are you talking about the CALL PRESENTATION key ?
tincho.rn
Post by tincho.rn »
In an attendant console (4035T), when you configure it, the REDIAL button is number 23. You have to counter in the next way:
111 222 13 14
333 444 --- ---
555 666 --- ---
11 12 23 24
Return to “Attendant”
