We have 4039 a phone in a public area which is there to allow people to call a call centre. However the customers have trouble using it as they need to press the send DTMF key before they select the call centre options.
So the question is, is there anyway to change the 'user' programing or COS so that DTMF sending is enabled by default on only this phone?
Send DTMF. Change change to make it default?
Re: Send DTMF. Change change to make it default?
Prog a button on the phone to dial Call Centers and Add send DTMF code.
Eliott_DUP
1) Number + Suffix for DTMF End To End Dialling should work. (cheap)oldboy wrote:Prog a button on the phone to dial Call Centers and Add send DTMF code.
2) Use Genesys and a RSI with a CED Strategy
3) Go trough a Trunk Loop with Auto-DTMF (not nice)
Will give that a try. Pity it isn't like most things on this system and user selectable through a COS.
Isa
Search for the following discussion on this forum: "DTMF on 4004 handsets"
There are a lot of posts regarding DTMF settings
