Change Date & Time
marros
Change Date & Time
Post by marros »
I have an OmniPCX Enterprise and also have 4760 for configuration.
I need to knwo how I can change the time and the format of the date that is shown on all the handsets (we a mixture of reflex easy, premium and advanced handsets)
Any Help would be greatly appreicated.
Open configuration. In "system" you will find date/tame.
More easy - connect with telnet and use "swinst" (expert menu/ system management/ data&time update.
freedom
Post by freedom »
In some countries (like The Netherlands) it is also possible to synchonise time on T2 and T0 trunklines.
Just put the parameter to YES under shelf - board - digital access.
After this change you will not haveto adjust time and date by hand.
Return to “GENERAL”
