4059 installation - device number?
nowi_DUP
Post by nowi_DUP »
It seems I missed the 4059IP installation process during my training :D
What is the Device number? I checked the doc but no word.....they use A10
At the moment I have a connection problem between 4059IP and OXE 8.0, checked the licenses and the hardware.mao mentioned in the TCO.
Appli: SBS Session
Msg: NOT_USED
Status: L3OPEN, I2 protocol init failed.
I sniffed...and first there is a TFTP download and then some UDP data exchange....
Any idea?
Thx,
Nowi
knightr1der
Re: 4059 installation - device number?
Post by knightr1der »
nowi wrote:What is the Device number? I checked the doc but no word.....they use A10
Yes, they use A10 - But what number have you used when you created your attendant in the OXE? That is the device number you need.
nowi_DUP
Post by nowi_DUP »
thx....seems logical...unfortunately the problem still exists...
Created an User (3010) for the associated set
Created an Attendant Group 0, Nr. 3000
Checked the Attendant Group Call Distribution
Created the Attendant Set (type 4059IP) Nr. 3001 , Group 0, ID 0 with the associated phone set (3010)
Created Prefix for Attendant Group Call.
Is there a debug command to check the SBC Session.
I use 4059IP Version 5.04, tried also with 5.03
Thx,
Nowi
knightr1der
what type of set is 3010?
nowi_DUP
Post by nowi_DUP »
4038
nowi_DUP
Post by nowi_DUP »
Ahhh...between your information about the device number an me trying it out I had a REAL network problem.
Now it is working ! Stupid me!!!
Thx for your support...
Ghuntar_DUP
Post by Ghuntar_DUP »
Any idea?
I had the same problem, but it's solved :
If a firewall/router is between your 4059IP and your OXE, You need to open traffics :
1) From OXE to 4059IP :
- TFTP port (69)
- All ICMP traffic (ping, etc...)
- UDP port 32520
2) From 4059IP to OXE :
- TFTP port (69)
It seems to work that way, I'll update if something goes wrong.
Ghuntar.
Ghuntar_DUP
Hum, I can't EDIT my post... Just to say that the "post subject" is not the best... Maybe I should make a new post about network ports...
Ghuntar.
Eliott_DUP
Post by Eliott_DUP »
Just to have it for future reference...
The device number to be entered in the software application is the number displayed by opstat command.
sckorcho
Post by sckorcho »
I have the same problem, i already put the OXE and the 4059 ip in a hub and i have the same problem
L3OPEN,I2 init failed
anyone knows what´s happening??????
help me please
Return to “Attendant”
