4200d
selectt_DUP
4200d
Post by selectt_DUP »
A customer asked me how they would get call metering output from a 4200d.
I know a 4200e output is from the CM board, but how is the 4200D's output provided ?
Is it via a v24 adaptor ?
cheers
Friday
Re: 4200d
Post by Friday »
selectt wrote:A customer asked me how they would get call metering output from a 4200d.
cheers
You are correct, a V24 adaptor is the way to go and may be used on any 4200
You will find the setup in this post viewtopic.php?f=24&t=1589
This is for OXO, but is very similar to 4200.
For testing just connect the serial port on tyour laptop to the V24 . In Hyperterminal you should see the tickets arrive.
selectt_DUP
Re: 4200d
thanks was not sure about the 4200d as never used it for a while.
Re: 4200d
selectt wrote:thanks was not sure about the 4200d as never used it for a while.
Yes very few around these days :)
et
Re: 4200d
Post by et »
On the top of 4200D box (without plastic cover) you can find two DB9 sockets: one for programming (administration) purpose and other - for metering.
Krusty65
Re: 4200d
Post by Krusty65 »
et I thought the second db9 was 4 voice mail. Will check but believe that this was its only function.
et
Re: 4200d
Post by et »
OK, I was wrong, second DB9 for IVPS.
Return to “42xx Systems”
