Display all 1718 possibilities? (y or n)
nyopen
Post by nyopen »
Type <ESC><ESC> under mtcl.
Two <Esc> (for Chorus) or <TAB> (for Linux) used when you write begining of command and want automatic completion or consult with commands which begins from same leters.
If you type twice <Esc> system suggest all commands.
For Chorus just type "help", you will have menu.
Return to “Usefull commands”
