Help with upgrading OmniSwitch 6800
zwp015
Post by zwp015 »
Does anyone know how to upgrade the OmniSwitch 6800. I have the install instructions and need to use command line to install. The instructions say to install the image files with a install *.img The files I downloaded are in the mib format and so I am at a loss here. Or if someone could share how I can update just the ssh module that would take care of my present needs.
Thanks!
zwp015
benny
Re: Help with upgrading OmniSwitch 6800
Post by benny »
The *.mib files are not the good ones. Those files are used for a NMS like Alcatel-Lucent OmniVista or HP OpenView etc.
If you are a BP you can download the images from the BPW (Business Partner Web(-Site)).
Download the latest 6.1.3.xxx.R01 maintenance release - not the GA (Generally Available).
Return to “OmniSwitch 6800”
