Swinst locked or does not load with easy and expert options
swinstu
Post by swinstu »
I would like to know if there is an easy way of performing an end task (kill) on the application that runs "Swinst Options", as I have encountered a few systems that seem to lock up swinst from time to time, mainly Release 7.1 OXE systems. Any feedback would be appreciated. Thanks
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
Eliott_DUP
Re: Swinst locked or does not load with easy and expert options
Post by Eliott_DUP »
lock up swinst
Can you describe the behavior more detailed?
"Swinst" is not a single process.
It's a collection of scripts and binaries (see /DHS3bin/soft_install/bin/ directory)
Normally the only option which makes trouble is the backup but in R7.1 there should be the option to override the lockfile.
In older versions you have to enter rm -rf BCK_working in the tmp or tmpd directory. (check which one before)
If you have other trouble, you could try a "trace":
Switch to user root
Edit the file /DHS3bin/soft_install/bin/bck and add a line set -x at the beginning of the file
:shock: Elliot by a chance you helped on OXE development at some time????
knightr1der
Post by knightr1der »
cavagnaro wrote::shock: Elliot by a chance you helped on OXE development at some time????
Yeah - in his sleep :lol: :lol: :lol:
Just don't forget who Eliott works for Cav - Europe's premier Alcatel BP 8) same as errrrrrrrmmmmmm :lol:
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
But ermmm cleans floors then? :lol: :lol: or is the valet parking guy?? :lol: :lol: now I understand your fascination with KITT :lol: :lol:
knightr1der
cavagnaro wrote:But ermmm cleans floors then? :lol: :lol: or is the valet parking guy?? :lol: :lol: now I understand your fascination with KITT :lol: :lol:
Nothing can eXplain yOur stupidity! :lol:
Eliott_DUP
No. Just more than 10 years experience...
swinstu
Post by swinstu »
Switch to user root
Thanks for the quick reponse Elliot. I am only talking about the part whereby we can access the swinst menu after entering the swinst command and password which loads with Easy and Expert Menu and since this menu does not load, even after a 20 minutes, I am unable to perform immediate backups. An example of what loads is
below:
(Note: this is from a release 6.1 system)
Alcatel OmniPCX Enterprise
standard installation last performed: 29-Jan-1992 06:05:59
# The role of the CPU is MAIN
Application software identity
R6.1.1-f2.502-12-d-as-c80s1
Business identification: R6.1.1
Release:
DELIVERY f2.502
Patch identification: 12
Dynamic patch identification: d
Country: as
Cpu: c80s1
ACD VERSION
release : 6
bug_fixing : 1
protocol_id : 90
version_dy_hr_stat : 11
(31)xa000000> swinst
Password:
Last installed delivery
DELIVERY f2.502.12.d
Is there any means of resolving this issue. A colleague of mine suggested: su swinst (password) then Cntrl+D and then swinst (password) but this does not work all the time.
Thanks once again.
Cheers
SWINSTU
ACSE OXE R12.1
Eliott_DUP
Try this:
su <Return> (and enter root password)
vi /usr2/soft_install/bin/.profile <Return>
i (for insert)
set -x <Return> (add this line)
<ESC> :wq <Return> (ESCape for command mode and :wq for write and quit)
Then type swinst and post the output.
To remove the set -x line:
dd (for delete line)
If you do a mistake, cancel the vi with
<ESC> :q! <Return> (ESCape for command mode and :q! for quit w/o writing)
swinstu
Post by swinstu »
Thank you very much, I will give that ago next time I come across any issues relating to swinst menu.
SWINSTU
ACSE OXE R12.1
Return to “Swinst”
