view log file of any extension
rotonpur_DUP
Hi every one
need some help. already i ahve Searched to fund but couldn't, so writting. is there any log file in the system (4400-oxe)which records all type of action and modification made from/to any extension? if there is, how to see that log file content.
Thanks in advance.
Thanks in advance.
knightr1der
Re: view log file of any extension
I don't think a log file is created/saved automatically.
I think you can set up a trace and capture or save it to a file, but I don't have Eliotts (or other superguru) brain so cannot tell you the answer for that command.
Supeguru's - WAKE UP... your assistance is needed
eh what what? 5 more minutes let me sleep
no way I can answer that
Maybe SNMP traps? OXE has?
knightr1der
No No - I said SUPERGURU - you can carry on sleeping you Avatar Thiefcavagnaro wrote:eh what what? 5 more minutes let me sleep
SNMP etc.. No, the OXE has some powerful trace commands that can capture even when the user went for a pi$$ (or even they went for a $4it)
Meanwhile - we wait for Eliott to;
zanex
not sure what you are exactly after
maohist will give the last couple of hundred database changes and you can search by xtn
there are other traces you can run for database transactions for a specific xtn
you can trace on UA signalling on an xtn, what buttons are being pressed etc
for the traces look at the TB for traces
rotonpur_DUP
maohist only say that there was a modification or update of an extn, but not telling/showing detail action.
Since R8 (I think) they introduced more detailed info. See p.2 - detailed mao historyrotonpur wrote:maohist only say that there was a modification or update of an extn, but not telling/showing detail action.
0 - Exit
1 - Edition of mao history
2 - Edition of detailed mao history
3 - Edition of call handling history
4 - Edition of LOGIN only
5 - Edition of matched string
6 - Edition of ACTION on MAO
7 - Writing in file of detailed mao history
8 - Reading of detailed mao history file
- tot3nkopf
You can use:
srvtrace
traced &
It will return the changes to the SQL database. You can capture them and interpret them.
After using it kill the srvtrace service.
Regards.
srvtrace
traced &
Regards.
The good solution will be a maohist feature improve like the incidents in R8. Perhaps in R9 ?
Meanwhile, perhaps the solution can be the use of logrotate onto the maohist files. Never try, but it can be the solution.
Sadim
Sadim
