Clearing manualy locked Z ports.
GaryLock
Post by GaryLock »
Any ideas how to remotly unlock Analoge ports?
I know from the device ie fax you can dial 171515 but anyway to do this remotly?
Also i know to prevent this from happening again take out lock/unlock from int numbering...
Cheers
Gaz
Eliott_DUP
Re: Clearing manualy locked Z ports.
Post by Eliott_DUP »
mgr -> Users -> Go down -> Dynamic state user -> Lock + False
or from command line
maoupdate -s <Directorynumber> -nolock -exec
Use Phone Category / Phone Feature Cat to disable this feature.
GaryLock
Post by GaryLock »
Sorry - its for OXO not OXE....
Should have stated that...
Eliott_DUP
Upps. :shock: Sorry. :oops: I used the View new posts button and forgot to read in which Forum the Topic was created. :roll:
It's not possible for OXO (except dial the prefix to unlock the set). Only way to disable the feature: Delete the prefix :?
:lol: you had the "answer-them-all" moment Elliot?
Eliott_DUP
cavagnaro wrote::lol: you had the "answer-them-all" moment Elliot?
8) Yes. But sometimes it seems to be better to read the screen content more carefully ... :roll:
Jigger
Post by Jigger »
I thought if you put the phone in UA state then back as the modem - it would default??
i could be wrong tho
Return to “Configuration”
