Problem with 4018
Problem with 4018
Phone is stuck in space, it was working well for 2 or 3 months, and for no reason changed from static to dynamic adressing. I set the parametars for previous values but now I have the problem. Now phone is stucked with message on display " 3/5 configuration downloading". all parameters are set ok, cables and all other equipment is ok. Is there a master reset for the phone?
- cavagnaro
Re: Problem with 4018
have you tried to delete and recreate the extension?
- frank
A phone does not change from static to dynamic..
And you can't change this from the PBX.
Maybe one of your users got an account in this forum and played with it ?
Check under User / TSC-IP , and delete the MAC ADDRESS.
Then double check your configuration with another phone.
Check the VLAN settings at the end of the IP configuration too.
