Cannot complete dialing
enjoyjonnel
Post by enjoyjonnel »
We are having some situation if the users wants to call to other extension numbers they cannot complete the dialing. Say for example if we want to call a 4 digits extension (Eg: 7004) all users can only dial 3 (Eg:700). I captured a incident during that dialing (Incident:1721). What I do is delete that extension and re create it, the problem repeated but on the other extension. And I have to do that work around from time to time. How can I can resolve this issue?
Jonnel
Eliott_DUP
Re: Cannot complete dialing
Post by Eliott_DUP »
1721 is a backtrace - this can have many reasons.
Maybe you have a database or software problem.
Try the cdmao; checkdb command to get more infos
and also enter excvisu and post it here.
Also post the result of tradna <directorynumber>
mysticalself_DUP
Post by mysticalself_DUP »
What is the full patch of the pcx.It seems to be a bug on rel 8.
enjoyjonnel
What I observe in this, is if I use DECT or Reflexes the phone will ring but if I use 8 or 9 series as my caller the call will not succed.
phengvanna
Post by phengvanna »
Actually this problem appear on digital phone set
try to change timer number 3 and 13
Regards.
Vanna
Return to “Users”
