Virtual chassis rebuild
dtdamen
Post by dtdamen »
Hi guys,
I`ve got a single Alcatel 6560 running in a productive enviroment. Now I´d like to expand this device to a virtual chassis with 2 devices.
I know that, when I connect a second device to the first master device via DAC cable, that nothing will happen. The second device also
comes up as a second master and thats it.
Is there any chance to get the VC installed without the need for a complete re-installation (all *.cfg files delete on both devices, restart both devices and vc will build up)?
Thomas
Cristek
Re: Virtual chassis rebuild
Post by Cristek »
Should be fairly simple, at least on paper:
Check the current chassis-group of your already existing device (in this example its 45):
-> cd working
-> more vcsetup.cfg
! File: /flash/working/vcsetup.cfg !
! Virtual Chassis Manager:
virtual-chassis chassis-id 1 configured-chassis-id 1
virtual-chassis auto-vf-link-port 1/1/27
virtual-chassis auto-vf-link-port 1/1/28
virtual-chassis chassis-id 1 chassis-group 45
! PLEASE DO NOT MODIFY THE AREAS OF [SAVED INFO xxx]
! [SAVED INFO VC IDs] 3
! IP:
Then, boot the second switch as a standalone device in your lab.
Edit the vcsetup.cfg with vi, or create one in your favorite text editor.
This file should manually assign the ID of 2 where a '1' is present. You should also change the chassis-group to match the main switch. Something like this:
virtual-chassis chassis-id 2 configured-chassis-id 2
virtual-chassis auto-vf-link-port 2/1/27
virtual-chassis auto-vf-link-port 2/1/28
virtual-chassis chassis-id 2 chassis-group 45
Then plug in the DAC cables and the second switch will reboot to join the stack.
Check status with show virtual-chassis topology
dtdamen
Post by dtdamen »
Perfect, thanks bunches for your quick reply
Thomas
dtdamen
Post by dtdamen »
Hi guys,
for whatever reason, it does not work.
I´ve got a running switch with the following vcsetup configuration:
more vcsetup. cfg
! Fi le: /f lash/working/vcsetup. cf g
! Vi rtual Chassis Manager:
virtual-chassis chassis-id 1 conf igured-chassis-id 1
virtual-chassis vf-l ink-mode auto
virtual- chassis auto-vf-l ink-port 1/1/53
virtual-chassis auto-vf-l ink-port 1/1/54
Have re-started a brand new switch from scratch and have edited both vcsetup files (working and certified directory)
more vcsetup. cfg
! Fi le: /f lash/working/vcsetup.cfg
virtual-chassis chassis- id 2 configured-chassis- id 2
virtual-chassis auto-vf-l ink-port 2/1 / 53
virtual-chassis auto-vf-l ink-port 2/1 / 54
cd /flash/certified
more vcsetup.cfg
! Fi le: /flash/working/vcsetup.cfg
virtua-chassis chassis- id 2 configured-chassis- id 2
virtua -chassis vf-l ink-mode auto
After connecting DAC cable and re-start the new sitch does not join the VC
Jan 2
. isisVc vcprot INFO message:
+++ vcxEI ect ionT i merExpi rat ion@1381 :
I am the Master: chassisld 2 chassisMac 78:24:59:88:90:df
CMM has reached the ready state Cl-8]
hass is Superv isi on:
Jan 2
. vcmCmm m ip INFO message:
tcn_t raps@15845: Generate trap chassisStatusChange (120) (chassis 1,
CMM: vcmCMM send
CMM: raps@15845: Generate trap chass sStatusChange (120) (chassis 2,
Jan 2
. Chass sSuperv i sor rel oadMgr INFO message:
Redundancy t i me
exp red
updat ing next running to "Ork ing
status Reboot -NotJoined, ret 0)
status Reboot -Added, ret 0)
What steps I´m doing wrong?
Thomas
Cristek
Post by Cristek »
You have spaces in the vf link ports
You have 2/1 / 53 instead of 2/1/53
Other than this at a first look I dont see anything else
dtdamen
Post by dtdamen »
Good morning guys,
sorry there is an error in copy and paste.
In the original cfg file I don´t have blanks
Thomas
dtdamen
Post by dtdamen »
Hi guys,
finally I got it running.
It was a faulty DAC cable :lol: . For the tests I`ve used only one cable für the VC connection.
With a new cable the VC came up immediately. :mrgreen:
Nevertheless, thanks for support
Regs
Thomas
