DHCP Snooping Setup
mumer2
DHCP Snooping Setup
Post by mumer2 »
Dear Team.
I am stuck in DHCP snooping scenario. As i use to enable DHCP-Snooping on the switches, the PABX stops to give ip addresses to the IP phones.
PABX is connected with Server farm switch with VLAN 20 for voice. I enabled VLAN base DHCP-snooping on this switch and trusted the port on which the PABX is connected (1/1/10). Configuration on server switch for DHCP-Snooping as per below:
vlan 20 members port 1/1/10 untagged
dhcp-snooping vlan 20 admin-state enable
dhcp-snooping binding admin-state disable
dhcp-snooping linkagg 1 trust
Core Switch Configuration:
dhcp-snooping linkagg 1 trust \\connected to server switch
Distribution Switch Configuration
dhcp-snooping linkagg 1 trust \\connected to Core switch switch
Access Switch Configuration
dhcp-snooping linkagg 1 trust \\connected to Distribution switch switch
Guide me where i did mistake in the configuration or how can i more secure the LAN network with L2 DCHP-Snooping configuration.
PABX (1/1/20) --- Server Switch (0/1) --- Core Switch (0/1) Distribution Switch --- (0/1) Access switch (1/1/1 -10) Ip Phones
I had attached the diagram for your further reference so it would be easy for you guys to give me a suitable solution.
Cristek
Re: DHCP Snooping Setup
Post by Cristek »
Hi!
Your diagram is missing, but from the information you posted, it looks like you are missing dhcp-snooping port 1/1/10 trust on the server switch :)
mumer2
Post by mumer2 »
Sorry for that.
I had configured port trust on Server Farm switch. but still facing the issue.
Is the configuration fine that i had done.
Do i need to configure DAI also along with DHCP-Snooping.
Cristek
Post by Cristek »
Then try re-enabling the binding table on all switches. I never disable it when I implement dhcp-snooping (it's on by default I believe).
I don't see any miss config. Important to trust the ports/lag to the dhcp server. This you have done. Also correct that dhcp binding should be enabled.
With your config dhcp server should work. I seldom use it per vlan - normaly you can activate dhcp snooping global.
But what do you expect from your config? Only to avoid wrong dhcp server? Or also to protect against ARP spoofing attack?
BR Silvio
