Compatibility Issues Omniswitch 6860E and 6250
almadar
Post by almadar »
I have been having network issues with alcatel switches. I have multiple access switches OS6250 connected to a core switch OS6860E. After a while the network starts acting out (connection timeouts and slow connectivity). At first, I thought the problem was with the access points (AP1101) since it's mostly where the problem appears first through client complaints. The configuration is simple: A management VLAN for switches and access points and a data vlan for the users. After working on a second project which has OS6350 access switches and AP1201 access points and one of the access switches is a OS6250. The same problem occured only on access points and clients connected to OS6250 which lead me to believe that there's an incompatibility issue between the firmware on the OS6250 and the newer OS6860E. My question is does anyone know of a feature or protocole that is on the newer versions of alcatel's OS that might no work well or cause network problems with the older versions? Maybe there's a protocol version difference that is causing issues.
Note:
- I updated all devices to the latest availabe version of their respective firmwares.
- The configuration is very basic only vlans and management IPs configured on the switches, everything else is left as out of the box defaults.
- I attached the config for one of the OS6250s and the OS6860E.
Re: Compatibility Issues Omniswitch 6860E and 6250
I do not think that there is a problem with compatibility. 6250 has only 100Mbs ports. Also the PoE is max 15W.
You should exchange this very ols switches.
almadar
Post by almadar »
Thanks, I thought so. But what if changing 10 switches isn't an option (client won't accept). Having 100Mbps ports shouldn't be an issue if the traffic isn't high (2 WAPs with max of 10 clients each and 3 IP cameras per switch) and the OS6250 switches don't have this problem in another site where the core switch is an older OS6850 With much higher traffic (IPTV, CCTV, VOIP and internet). Also the intenet bandwidth isn't very high (100mbps to the whole site).
