fault 2771
boukaaza
fault 2771
Post by boukaaza »
Hello everyone,
I’m experiencing a fault in my Alcatel OXE system, and I would appreciate your help in diagnosing and resolving it. Unfortunately, I haven’t been able to find a solution so far. :?
Here are the details of the issue (PJ)
Re: fault 2771
You have some problem with internode link - tunnel/X25.
Return to “X25”
