represent
represent
I just leaned that new one
represent gives a list of the demi-com (half-com) actually in use.
You will see who is calling who. Then use eqstat n xxxxx to find who's the number calling/called
la_toupie
Post by la_toupie »
It's the same thing ''listincall'', isn't it ?
listincall gives you too much shit :-)
represent is much more clearer :-) Just a personal choice :-)
arctus
Post by arctus »
I mostly use "t3 |grep _NUMBER" to trace calls in real time. You can even trace digits as they are being typed into the set! I will also try "represent" and see what it can do for me.
You can see digits are they are dialed ONLY if you use NO OVERLAP I think. If you use Overlap, the PBX will send all at once.. :-)
Alejandro
Post by Alejandro »
How to stop command "t3 |grep _NUMBER"?
tia
"DEL" or "CTRL-C"
Alejandro
Post by Alejandro »
Thanks, vad.
"DEL" worked fine, but not "CTRL-C".
Thanks again.
DEL for Chorus (up to R50.1Ux), Ctrl-C for Linux (from R5.0Lx).
Return to “Usefull commands”
