MVRP turning back on
rbowker
Post by rbowker »
We disable MVRP on our basic config of the 6560s we have deployed but I have found some of my stacks are re-enabling it after coming back online after power failure. I have double-checked that the config is saved and mvrp is disabled but it still comes back on after. Why might this be happening and how can I prevent it?
Re: MVRP turning back on
probably the most done mistake. Please disable auto-fabric with
check with: show auto-fabric status
disable with: auto-fabric admin-state disable
rbowker
Post by rbowker »
Thank you very much, Silvio!
