ALE 300 stuck on boot
maxmania
Post by maxmania »
Hello everyone,
I got an ALE300 phone, when I plug the phone it star to boot, show on the screen ALE300 banner and flash do green led. and stay there!! Any ideas??
Best Regards
Jose Alves
Re: ALE 300 stuck on boot
What does the screen say? Can you share a pic of the screen?
Al-Yat
Post by Al-Yat »
I have the same issue, the phone button (to the right of 3) flashes a few times when I plug the power back in.
What network is it connected to?
Are you using DHCP?
What happens if you select the bottom left button next to the gear icon
Return to “Phones”
