Any possible to do remote port mirroring on omniswitch?
zlinuxboy
Post by zlinuxboy »
cisco and huawei support rspan or erspan.
Do os6900 support this feature, I can found these feature on official guide.
And I find there is an erspan0 port on os6860-24, might be 6860 support erspan?
SHASTA #-> ip link ls erspan0
9: erspan0@NONE: <BROADCAST,MULTICAST> mtu 1450 qdisc noop qlen 1000
    link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
Cristek
Re: Any possible to do remote port mirroring on omniswitch?
Post by Cristek »
Doesn't look like you can do it based on the Guide. I don't see anything there either.
zlinuxboy
Post by zlinuxboy »
Then could I capture packet/ethernet frame on os6900/6860?
I am trying to figure out the process of isis adjacent built by observ the hello pdu.
there are a lot possibilities f.e. debug ip packet, port-mirroring, port-monitoring, rpmir, qos log and tcpdump
zlinuxboy
Post by zlinuxboy »
@silvio
What do you mean of tcpdump? I have been tried tcpdump under su mode of omniswitch, but no isis traffic captured.
could you elaborate debug ip packet, isis is running on top of ethernet layer, so how to utilize it for observe isis traffic?
for tcpdump:
> tcpdump -D to see the interfaces
> tcpdump -i any to see traffic at all interfaces
I do not know at what point of the interface tcpdump is capturing. Maybe the spb-isis packets (with the ah-header) are created at the "more" outside.
you are correct: debug ip packet is for ip packets only.
But port-monitoring and -mirroring should work.
Return to “OmniSwitch 6900”
