Hello, I hope you're doing well.
I am experiencing an issue with external calls to numbers starting with 011. When I try to make a call from my Alcatel 4039 office phone, it displays "Out of Service".
When I run the command trkstat -r 6 (the trunk that handles these calls), I get the following output:
trkstat -r 6
Wed Feb 19 13:37:07 WAT 2025
| T R U N K S T A T E Trunk group number : 6 |
| Trunk group name : GAB TLC S |
| Number of Trunks : 21 |
| Index : 1 2 3 4 5 6 7 8 9 10 11 12 13 |
| Neqt : 655 1018 1017 1016 1015 1014 1013 1012 1011 656 379 654 653 |
| State : hs hs hs hs hs hs hs hs hs hs hs hs hs |
| Index : 14 15 16 17 18 19 20 21 |
| Neqt : 652 651 650 649 383 382 381 380 |
| State : hs hs hs hs hs hs hs hs |
When I run the command **trkvisu 6**, here is the result :
trkvisu 6
Wed Feb 19 13:46:55 WAT 2025
local TG ;
****************** data in Trunk_Group structure ****************
******** data REMOTE TRUNK
TrunkName = GAB TLC S
discrLogId = 0 ton_a_used = 0 em_repfix = 0
privLine = 0 reservop = 0 reserauto = 0
Trunksearchs = 0 ftranscom = 0 frondier = 0
typTrunk : (1) => BCATAXE
Next_Trunk = -1 nbdigitsem = 0 tab_proto = -1
node_number = 0
network_number = 15
trunk_reg_sig = 0
cat_restrictionService_in = 10, cat_restrictionService_out = 10
Priority ===> Level= 0, Mode= 0, Preemption= 0
mpt1343 = 0, callbackTrunkbusy = 1 rerouting = 0
******** data Link
cat_signa = 255 ch_channelb = 0 network_mode = 0
| NEW ocupjonc
| i = 0, min = 0, max = 1465
| last it used = 0, nbr_trunk_created = 0
| nbr_trunk_busy : start = 21 arrived = 0 mixed = 21
| outservice | res | Busy | nulog |trans|neqtdyn|E64 RN64 EN64| OVPN | neqph | adr
| OUTOFSERVICE | no | DEP | 169 | 0 | 655 | 1 0 0 | 0 | 655 |1-5-6-0
| OUTOFSERVICE | no | DEP | 178 | 0 | 1018 | 1 0 0 | 0 | 1018 |1-18-7-0
| OUTOFSERVICE | no | DEP | 177 | 0 | 1017 | 1 0 0 | 0 | 1017 |1-18-6-0
| OUTOFSERVICE | no | DEP | 176 | 0 | 1016 | 1 0 0 | 0 | 1016 |1-18-5-0
| OUTOFSERVICE | no | DEP | 175 | 0 | 1015 | 1 0 0 | 0 | 1015 |1-18-4-0
| OUTOFSERVICE | no | DEP | 174 | 0 | 1014 | 1 0 0 | 0 | 1014 |1-18-3-0
| OUTOFSERVICE | no | DEP | 173 | 0 | 1013 | 1 0 0 | 0 | 1013 |1-18-2-0
| OUTOFSERVICE | no | DEP | 172 | 0 | 1012 | 1 0 0 | 0 | 1012 |1-18-1-0
| OUTOFSERVICE | no | DEP | 171 | 0 | 1011 | 1 0 0 | 0 | 1011 |1-18-0-0
| OUTOFSERVICE | no | DEP | 170 | 0 | 656 | 1 0 0 | 0 | 656 |1-5-7-0
| OUTOFSERVICE | no | DEP | 158 | 0 | 379 | 1 0 0 | 0 | 379 |0-18-3-0
| OUTOFSERVICE | no | DEP | 168 | 0 | 654 | 1 0 0 | 0 | 654 |1-5-5-0
| OUTOFSERVICE | no | DEP | 167 | 0 | 653 | 1 0 0 | 0 | 653 |1-5-4-0
| OUTOFSERVICE | no | DEP | 166 | 0 | 652 | 1 0 0 | 0 | 652 |1-5-3-0
| OUTOFSERVICE | no | DEP | 165 | 0 | 651 | 1 0 0 | 0 | 651 |1-5-2-0
| OUTOFSERVICE | no | DEP | 164 | 0 | 650 | 1 0 0 | 0 | 650 |1-5-1-0
| OUTOFSERVICE | no | DEP | 163 | 0 | 649 | 1 0 0 | 0 | 649 |1-5-0-0
| OUTOFSERVICE | no | DEP | 162 | 0 | 383 | 1 0 0 | 0 | 383 |0-18-7-0
| OUTOFSERVICE | no | DEP | 161 | 0 | 382 | 1 0 0 | 0 | 382 |0-18-6-0
| OUTOFSERVICE | no | DEP | 160 | 0 | 381 | 1 0 0 | 0 | 381 |0-18-5-0
| OUTOFSERVICE | no | DEP | 159 | 0 | 380 | 1 0 0 | 0 | 380 |0-18-4-0
| CallRestrictionService | neqt_dcom_ass | Prio |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
| 10 | -1 | 0 |
index_max = 1465 ; nbjonc = 21
cristal = 0 1 2 3 4 5 6 7 8 9 10 11
LastTrunkused = 0 0 0 0 0 0 0 0 0 0 0 0
cristal = 12 13 14 15 16 17 18 19
LastTrunkUsed common = 8 idx_rfo = 0 channel_reserv = 0
dert0_used = 0 dert0mixt_used = 0 dert0wo_used = 0
******** data TRUNK_LOCAL
a_paying = 0 Trunkdisa = 0 itpermnt = 1 trans_num = 0
tr_q23 = 0 reach_boss = 0 secretcode = 0 ach_film = 1
accesscode = 0 gp_d_Hold = 0 categ_ptt = 0 blf etat = 1
entity_nr = 1 nb_digit_used = 4 Trunkdissu = 0 dto_about = 0
reused_channelb = 0 number_to_be_added : .
mode_ddi = 0 refptt = / / nbchminp = 0
x25used = 0
vpnRate = 50 vpnCostLimit = 0 immTrkForVpn = 1
businessPercent = 0 nbACDCall = 0 tax_nds = 0
send_prog = 1 ip_qual_prof = Profile #1
t2spec = S_NORMAL d_channel_hyb = 0
"When I perform an **rstcpl** on cards **1-5**, **1-18**, and **0-18**, which are **NDDI** and **NDDI2** cards, their status changes from **"HS"** to **"F"**. However, when I try to make a call, the status suddenly changes from **"F"** → **"B"** → **"HS"**, and no calls go through.
Does anyone have a possible solution?"
T R U N K S T A T E HS
Jump to
- General topics
- ↳ Talk to the admins
- ↳ GENERAL
- ↳ Outside World
- ↳ PARTS
- ↳ Pre-Sales
- ↳ JOBS
- ↳ Remote assistance contracts
- ↳ Actis
- ↳ Equipement Pictures
- ↳ OT/OXE/OXO FEATURES REQUESTS
- ↳ Lucent Technologies
- IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS
- ↳ Beginner's questions about the Crystal Hardware
- ↳ Beginner's questions about the Common Hardware
- ↳ Beginner's questions about the (4400 / Enterprise) PHONE APPLICATION or OPERATING SYSTEM
- ↳ Beginner's questions about the OmniPCX OFFICE
- VOICE - Documentation
- ↳ OXE (Crystal / Common) - System Documentation
- ↳ 4760
- ↳ OXO - System Documentation
- ↳ Documentation
- VOICE - OXE (OmniPCX Enterprise)
- ↳ Shelf
- ↳ Media Gateway
- ↳ PWT/DECT System
- ↳ System
- ↳ Translator
- ↳ Classes of Services
- ↳ Attendant
- ↳ Users
- ↳ Users by profile
- ↳ Set Profile
- ↳ Groups
- ↳ Speed Dialing
- ↳ Phone Book
- ↳ Entities
- ↳ Trunk Groups
- ↳ External Services
- ↳ Inter-Node Links
- ↳ X25
- ↳ Data
- ↳ Application
- ↳ Specific Telephone Services
- ↳ ATM
- ↳ Event Routing Discriminator
- ↳ Security and Access Control
- ↳ IP
- ↳ SIP
- ↳ DHCP Configuration
- ↳ Alcatel-Lucent Series 8&9
- ↳ SIP Extension
- ↳ Encryption
- ↳ Passive Communication Server
- ↳ SNMP Configuration
- VOICE - OXE - Common topics
- ↳ MAIN
- ↳ ACTIS
- ↳ Asterisk
- ↳ Boards
- ↳ Bugs & Security issues
- ↳ Equipment Pictures
- ↳ Feature Request
- ↳ H323 / Sip
- ↳ IP / VoIP
- ↳ IP SECURITY / ENCRYPTION (Thales)
- ↳ ipTouch (40x8) issues and tricks
- ↳ Linux tricks
- ↳ MOH
- ↳ ON SITE TROUBLES
- ↳ Phones
- ↳ Sipfoundry
- ↳ Software Loading
- ↳ Swinst
- ↳ System Hacking
- ↳ Traces
- ↳ Usefull commands
- ↳ Voice Guides
- ↳ Wireless configuration and sets
- VOICE - OpenTouch
- ↳ MAIN
- ↳ OTEC - OpenTouch Enterprise Cloud
- ↳ OTBE - OpenTouch Business Edition
- ↳ OTMS - OpenTouch Multimedia Services
- ↳ OTSBC - OpenTouch Session Border Controller
- ↳ OTNS - OpenTouch Notification Service
- ↳ OTMC - OpenTouch Message Center
- ↳ OTFC - OpenTouch Fax Center
- ↳ OpenTouch Conversation
- ↳ Smart Guest Applications
- VOICE - BiCS
- ↳ MAIN
- VOICE - OXO
- ↳ MAIN
- ↳ Configuration
- ↳ 42xx Systems
- ↳ Networking
- ↳ H323 / IP / Pimphony
- ↳ Internet and related
- ↳ Applications
- ↳ Hotel mode
- ↳ DECT
- ↳ Hardware
- VOICE - Omni Suite
- ↳ OmniTouch 8400 Instant Communication Suite
- ↳ OmniTouch 8410 Instant Communication Web Services
- ↳ OmniTouch 8440 Messaging Software
- ↳ OmniTouch 8450 Fax Software
- ↳ OmniTouch 8460 Advanced Communication Server
- ↳ OmniTouch 8464 Meet-me Audio Conference Bridge
- ↳ OmniTouch 8660 My Teamwork Conferencing and Collaboration
- ↳ OmniTouch 8670 Automated Message Delivery System
- ↳ OmniTouch Contact Center Standard Edition
- ↳ OmniTouch Contact Center Premium Edition
- VOICE - Applications
- ↳ AECS - Alcatel Extended Communication Server
- ↳ Alcatel OpenTouch Customer Service
- ↳ Aviso
- ↳ Call Center SoftPanel (ALU ProServices)
- ↳ CCD / CCS / CCIVR
- ↳ Free Desktop
- ↳ GENESYS
- ↳ Hotel / Hospital
- ↳ Ip Desktop Softphone
- ↳ IpTouch Phones XML Applications
- ↳ MSAD
- ↳ MyIC (My Instant Communicator)
- ↳ My Messaging / IMAP
- ↳ My Teamwork (ex-eDial)
- ↳ OmniPCX Record
- ↳ OmniVista 4760
- ↳ OmniVista 8770
- ↳ OTUC
- ↳ PREMIUM / GCE
- ↳ Rainbow
- ↳ Ubiquity
- ↳ ENS - Emergency Notification Server
- ↳ VNA - Visual Notification Assistant
- ↳ VAA - Visual Auto Attendant
- ↳ VitalSuite
- ↳ VitalQIP
- ↳ Voicemail (46x5)
- ↳ XML Presentation Server & TAPI Server
- ↳ 4980 - WebSoftPhone
- ↳ 4625 Interactive Voice Response
- VOICE - Third Party Applications
- ↳ AGITO NETWORKS
- ↳ AUDIOCODES
- ↳ ASTERISK
- ↳ AVST
- ↳ CDR Real time on Ethernet
- ↳ CISCO
- ↳ NGINX
- ↳ NICE
- ↳ Notification Systems
- ↳ OAK
- ↳ SOURCE TECH
- ↳ systel
- ↳ IP Touch apps
- ↳ Click2Dial
- ↳ MYIC apps
- Voice - Virtualization
- ↳ AWS
- ↳ Linux KVM
- ↳ VmWare
- ↳ HyperV
- ↳ Other
- Alcatel Unleashed tools, documentations, and misc files...
- ↳ GitHub Script Repository
- ↳ "Home Made" documentations
- ↳ Alcatel Misc Documentation
- ↳ OFFICIAL TC's
- ↳ DIALER
- ↳ infocollect
- ↳ ipview analyzer
- ↳ motview
- ↳ sngrep
- ↳ VM_BACKUP
- ↳ Other Alcatel-Lucent tools
- Developer's corner
- ↳ AHL / OHL
- ↳ Alarming, Notification & Location
- ↳ CCTI / CCA
- ↳ CSTA
- ↳ My IC Phone
- ↳ My IP Touch Service for Enterprise
- ↳ O2G
- ↳ OmniVista 8770 User Provisioning
- ↳ SIP
- ↳ TAPI
- ↳ TSAPI
- ↳ Web Services
- Alcatel Data Equipment
- ↳ Security
- ↳ OmniAccess 3500 Nonstop Laptop Guardian
- ↳ Mobility
- ↳ OmniAccess WLAN Switching Systems
- ↳ OmniAccess WLAN 4302
- ↳ OmniAccess Wireless Access Points 41
- ↳ OmniAccess Wireless Access Points 65
- ↳ OmniAccess Wireless Access Points 60/61/70
- ↳ OmniAccess Wireless Access Points 80M
- ↳ Mobile IP Phones
- ↳ OmniAccess Devices
- ↳ OmniAccess 5780
- ↳ OmniAccess 5740
- ↳ OmniAccess 5510
- ↳ Network Management
- ↳ Omnivista
- ↳ Omnivista Mobility Manager
- DATA - Documentation
- ↳ Technical papers
- ↳ Troubleshooting guides
- DATA - Lan Switching
- ↳ OmniSwitch 10k
- ↳ OmniSwitch 9900
- ↳ OmniSwitch 9000 / 9000E
- ↳ OmniSwitch 6900
- ↳ OmniSwitch 6865
- ↳ OmniSwitch 6870
- ↳ OmniSwitch 6860 / 6860E
- ↳ OmniSwitch 6855
- ↳ OmniSwitch 6850 / 6850E
- ↳ OmniSwitch 6560 / 6570M
- ↳ OmniSwitch 6465
- ↳ OmniSwitch 6450
- ↳ OmniSwitch 6400
- ↳ OmniSwitch 6360
- ↳ OmniSwitch 6350
- ↳ OmniSwitch 6250
- ↳ OmniSwitch 2220
- ↳ OmniSwitch 2260 / 2360
- ↳ Legacy Devices (OS4024, XOS, OmniCore)
- ↳ OmniSwitch 6600 / 7000 / 8800
- ↳ OmniSwitch 6800
- ↳ OmniStack LS 6200
- ↳ Misc
- DATA - WLAN, Mobility and WAN
- ↳ OmniAccess WLAN Switching Systems (OEM)
- ↳ Mobile IPTouch Phones (MIPT)
- ↳ OmniAccess Stellar Express
- ↳ OmniAccess Stellar Enterprise
- ↳ Brick VPN Firewall
- ↳ OmniAccess 5740/5780
- ↳ OmniAccess ESR 5720
- ↳ OmniAccess 5510
- DATA - Network Management
- ↳ OmniVIsta 3600 Air Manager
- ↳ OmniVista 2500 v4.x
- ↳ OmniVista 2500 v3.5
- ↳ OmniVista 2500/2700 v3.4 and older
- ↳ OmniVista Cirrus
- ↳ Alcatel Quarantine Manager
- ↳ Fortigate Security
- DATA - Service Provider
- ↳ 5520 ASAM
- ↳ 5620 SAM
- ↳ 5650 CPAM
- ↳ 5670 RAM
- ↳ 5750 SSC
- ↳ 7210 SAS
- ↳ 7360 ISAM
- ↳ 7450 ESS
- ↳ 7450 Ethernet Service Switch
- ↳ 7750 Service Router
- ↳ 7705 SAR
- ↳ 7750 SR
