OAW-AP1301 IP address not saved after reboot
mod
Post by mod »
I’m using OAW-AP1301 configured with static IP address but each time I reboot IP is condigured in dhcp mode ! And again I connect to the default ip then change to static IP.
AP Group does not have IP address, I do not need cluster.
Is there a menu option to really save IP address ?
mod
Re: OAW-AP1301 IP address not saved after reboot
Post by mod »
For testing, I configured an IP address for AP Group. IP address for the AD Group is correctly saved after a reboot but still not for the IP adress of my AP.
I think there was an bug. So test the same with the newest software release.
BR Silvio
mod
Post by mod »
Hello silvio,
I’m waiting response from my reseller for new firmware.
Juliot
Post by Juliot »
HI
We have the same problem for 2 years. A New firmware cannot be found anywhere. My resseller is NOT a partner....
Where can i found that firmware??? Pls don't answer "on alcatel sso.ale-international.com
Thanks in advance
Return to “OmniAccess Stellar Express”
