How to block specific incoming DID
simon
Post by simon »
Hi all
Would anyone have an EASY Document on how to block incoming calls from a specific DID calling through a T1?
I found the doc in the system documentation, but it's really not an easy one.
If anyone has anything with example I'll take it.
Thank you all -
Re: How to block specific incoming DID
General application/ Caller/called filtering
Creater
Post by Creater »
You can block incoming calls from a specific DID through a T1 by configuring call filtering rules in your PBX or switch system. For an easier guide, I recommend referring to the system's user manual or support site for step-by-step instructions on setting up DID filtering with examples. If you need further assistance, feel free to reach out to your system's support team for more tailored documentation.
gramwilliam
Post by gramwilliam »
Use your PBX or VoIP system to block the DID Go to call routing or inbound rules Add the DID and set it to reject or hang up Check with your provider for exact steps.
See if this helps.
Return to “GENERAL”
