Set up Busy to extension
kalvinduy
Post by kalvinduy »
Dear Sirs,
How we can setup Busy function to extension when the phone is Busy?
Duy
kalvinduy
Re: Set up Busy to extension
Post by kalvinduy »
I mean when Internal call to the other extension is busy. It's immediate to indicated extension.
For exsample: Ext 6210 call to 6211 (is on busy). It's auto go to 6213 we setup BUSY to ext (6213).
kalvinduy wrote: 11 Nov 2024 02:20 I mean when Internal call to the other extension is busy. It's immediate to indicated extension.
TWO WAYS
1)Overfl.busy to assoc.set -----> true , it's under user dynamic state, indeed the associate set should defined under user config
Associated Set No. : 51009 , 6213 in you case x
x Cost Center ID : 255
2)forward type Immediate forward on busy ----> same under user dynamic state , Forward Directory Number have to be filled there
Review/Modify: Dynamic State Userq
Directory Number : 6211 x
x Instance (reserved) : 1 x
x x
x Forward + Immediate forward on busy x
x Forward Directory Number : 6213
Return to “Users”
