OXE : Can 1 user belong to several Hunt Groups ?
antopic
Post by antopic »
Hi all
I am told by my ALCATEL administrator that 1 user cannot belong to several HG on latest OXE.
He says it is an ALCATEL OXE limitation. : one user can only be in one Hunt Group.
Do you believe this ?
If yes this is a huge limitation of the new PABX we are currently installing, compared to the previous one.
Tell me.
Regards.
Re: OXE : Can 1 user belong to several Hunt Groups ?
hi
It is true. System Documentation mention "A set may not belong to more than one hunt group"
A work around would be to use MLA.
antopic
Post by antopic »
Hi Frank,
Thank you very much for this quick answer. I am so disapointed. But I know this limitation is real (whereas unbelievable).
Let's use the Multi-Lines workarounds (ALCATEL is so prehistoric ! )
1 more thing : where can I find latest OXE System documentation ?
Regards.
antopic wrote: 21 Aug 2024 10:16 Hi Frank,
Regards.
https://www.alcatelunleashed.com/viewtopic.php?t=24378
Which reminds me. I need to add R100.1 and R101
oldboy
Post by oldboy »
Why would you want to be a member of more than 1 hunt groups, Use MLA as Frank said, Use Virtual Analog Supervision, use a mini Contact center with PG's being able to answer from different number.
Few options!!
Return to “Groups”
