apologies for my lack of knowledge and detail when needed as I am a network/firewall guy and not an Alcatel engineer
also my first post here so be gentle
we are experiencing issues trying to get clients in the correct IP domain to receive the compression policy - this is only affecting our VPN users
I understand the problem and the only fix I can see if adding the individual host entries for our VPN range of 2000 users
so when vpn users connects on the VPN they get their IP and a subnet mask of 255.255.255.255 (palo - global protect)
but on the ip domain from what I can see we can define host address, ip range, ip subnet - but it seems that the Alcatel client on the laptop sends the gateway/CPU the subnet that being used on the vpn adapter - and for some reason the subnet has to match the ip domain setting
so my question is how I can get around this as I we cannot define an ip range 192.168.1.0 - 192.168.7.255 with subnet mask 255.255.255.255 (as truly this would be a 255.255.248.0 that would need defining)
but if it add individual hosts like 192.168.1.1 255.255.255.255 the host will fall into the correct domain
does anyone else have this issue and how do you get around it?
