ENS Migration to VNA
https://github.com/fgadot/AlcatelUnleashed
First script is out.
My scenario: A site with 800 zones in ENS.
My issue: Impossible to import those zones in VNA through a file. Ain't doing it manually :/
My solution: See the script called import_ens_zones.sh
It allows you to import the ENS Zones into VNA as Locations automatically.
Until ALE does something about it.... More scripts to come down the road!
Re: ENS Migration to VNA
There is a second script called import_locations.sh , which will automatically assign ENS ZONE to VNA LOCATIONS for each user.
If you see errors, it is most likely because you have new users in VNA which are non existent in ENS.
Easily fixable in VNA after the script is ran.
You can either filter users with no locations and fix it manually, or export all users into a csv file, correct, and re-import in vna.
hi Frank
when i'm trying your github i got this
This page isn’t working github.com didn’t send any data.
ERR_EMPTY_RESPONSE
same for this
https://github.com/fgadot/AlcatelUnleas ... ol%20error
Hi Haroun,
Can you go on GitHub at all, and look for alcatelunleashed ?
It's working for me from 2 different networks. Might be your network firewall?
yep i can't acces github at all may be a firewall rule in our network , il give it a try from my home
ok. let me know how it goes. if not I can upload the script here, but I corrected a couple of bugs already.
someone from France called me telling me that it was not working. I forgot that not all installations were in English lol..
Return to “GitHub Script Repository”
