Tandem
jadetay
Tandem
Post by jadetay »
Our Portable alcatel 8262 phones are linked to random PoE phones in my building. When someone dials a portable phone, a random office phone will ring. My company want to remove this however I cannot find how to do it.
We currently use the Telenet putty command prompt for the PoE phones and we remote into the website for the portable phones.
On the command interface for PoE the tandem function isnt set up.
And i have ensured on descend hierachy menu that all the functions for programmed keys are not assigned. Unsure what to do from here
Need help please :)
I cannot find hunting groups of the interface as this may be the issue.
Re: Tandem
Random - all the time the same. Or with new call will ring another office phone.
Fot 8262 phone - check - User/dynamic state user - forward, overflow?
Re: Tandem
Definitely not random, and certainly programmed somewhere.
jadetay
Re: Tandem
Post by jadetay »
vad wrote: 17 Jul 2024 22:58 Random - all the time the same. Or with new call will ring another office phone.
With a new call it will ring another office phone 😊 awesome thanks I’ll give it a try !
oldboy
Re: Tandem
Post by oldboy »
Also could be a set supervision of the portable on the office phoens
Return to “Phones”
