How to convert a switchport to UNP port on OS6900-X72
notsostabby
Post by notsostabby »
First time Omniswitch user here as I more familiar with cisco, I encountered this issue when we try to configure 802.1x on of our port. Tried to read the manual but every time i run this command "unp port 1/1/42 admin-state enable" i get an error "Port 1/1/42 is not a UNP port". Below is the version of our switch. Hoping someone can help me out. Thank you
System:
Description: Alcatel-Lucent Enterprise OS6900-X72 8.7.252.R02 GA, March 22, 2021.,
Object ID: 1.3.6.1.4.1.6486.801.1.1.2.1.10.1.6,
Re: How to convert a switchport to UNP port on OS6900-X72
there are a lot of other commands necessary to configure this port. You need to put the port in the unp port-type bridge. But this isn't enough..... read manuals, or look for other posts here or make a training for this switches.
BR Silvio
notsostabby
silvio wrote: 17 Jul 2024 11:19 there are a lot of other commands necessary to configure this port. You need to put the port in the unp port-type bridge. But this isn't enough..... read manuals, or look for other posts here or make a training for this switches.
BR Silvio
Hi silvio, apparently I did read the manuals and already make some research before posting it here about it, but nothing says anything about it. Other than running the commands but not totally explain how it works. I have totally no idea with omni other than the basic.
Return to “OmniSwitch 6900”
