Inter-Node ARS debug
directraw
Post by directraw »
Hello everyone!
Could you please check what wrong in settings?
I can not make a call.
I did all settings regarding to oxe12.4_sd_IP_PCXNetworks_8AL91007USAK_1_en-1.pdf (Alcatel-Lucent OmniPCX Enterprise Communication Server IP-PCX Networks) document.
Re: Inter-Node ARS debug
i see a mismatch in the config of remote node ip/x25 not used but tunel ip is configured 172...
second i see the S in the link that mean the link is saturated no free B channel
third and the most important you need licences for vpn
directraw
Post by directraw »
Hi haroun!
Got it, Thx for your answer!
I didn't upload license.
Is it OK to use ABC Logical Link between two OXE nodes?
In suproutage - S for telephone cost os Ok (we have VPN overflow configured).
What you see in suproutage for VPN cost?
Network (Routing) numbers (user from node 5) - declared on N4?
can not make a call - what do you mean? When you dial number - what happen exactly.
directraw
Post by directraw »
Hi vad, haroun!
I'm confused, there are so many type of connections between OXE systems (Hybrid link + VPN overflow, Direct IP Link, ABC-F Trunk Group ...)...
What is the best way to connect two OXE (CS + GW) pbx via IP network without any re-routing through public network?
directraw
Post by directraw »
Hello everione!
In my case I used DirectLink.
thanks!
R101 gets ride of Hybrid link / VPN.
Way to go now is Direct IP
Return to “Inter-Node Links”
