Switch config audit
vulkanmu
Switch config audit
Post by vulkanmu »
Hi all,
is there a way in Omni to look at all switches in the network and report which ones do not have their working and certified directories synced? I know I can do it through a CLI job, but is there an easier, more digestible way to do this? Thanks in advance.
Re: Switch config audit
I use the overview in "Managed devices". There are columns for it. You can order this column f.e. and you can move the important colums more in front via the toolbox.
BR Silvio
