QoS Policy from OS6900-X40 to OS6900-T24C2
mrenner
Post by mrenner »
Hi All,
i have a Problem migrating a QoS policy to a Switch.
On the OS6900-X40 (8.7.98.R03) i had a working policy with
policy condition VLAN401 source linkagg 28 source vlan 401
policy action Limit_500M maximum bandwidth 500M
policy rule Limit401 condition VLAN401 action Limit_500M
On the new OS6900-T24C2 (8.9.221.R03) i get
ERROR: Linkagg matching not currently supported
when i try to set the policy condition.
Is there another way to do this?
Michael
Re: QoS Policy from OS6900-X40 to OS6900-T24C2
You are correct. Also in cli guide from the newest release the linkagg isn't supported there.
I have no idea for a workaround :-(
Return to “OmniSwitch 6900”
