I have an Omniswitch 9900 switch that is currently running using the Certified configuration.
9900 > show running-directory
CONFIGURATION STATUS
Running CMM : MASTER-PRIMARY,
CMM Mode : VIRTUAL-CHASSIS DUAL CMMs,
Current CMM Slot : CHASSIS-1 A,
Running configuration : CERTIFIED,
Certify/Restore Status : CERTIFIED
SYNCHRONIZATION STATUS
Flash Between CMMs : SYNCHRONIZED,
Running Configuration : NOT SYNCHRONIZEDUnfortunately, it is a critical switch for the company and it is almost impossible to provide a maintenance window in which to restart it.
Here some info on the switch:
9900 > show system
System:
Description: Alcatel-Lucent Enterprise OS9900 8.5.255.R02 GA, August 29, 2018.,
Object ID: 1.3.6.1.4.1.6486.801.1.1.2.1.12.1.1,
Up Time: 220 days 9 hours 47 minutes and 4 seconds,
Contact: *******************,
Services: 78,
Date & Time: WED APR 24 2024 15:29:03 (CEST)
Flash Space:
Primary CMM:
Available (bytes): 1041235968,
Comments : None
Secondary CMM:
Available (bytes): 1188036608,
Comments : NoneAndrea
