Use of URL instead of IP in policy condition
thermseeker
Post by thermseeker »
Hello there
I have Omnivista 2500 running inside a restricted VLAN. It needs to regularly access the internet for several reasons, so I need to allow the IP addresses through the OS6900 which is our core switch. The thing is, I only have the URLs for the services OV2500 needs to access, and its related IPs change frequently. And the same is through for other applications I have running in my environment.
Is there a way to enter the URLs instead of the IP addresses in my set of rules?
Re: Use of URL instead of IP in policy condition
No, the switches don't support policies with url.
BR Silvio
Gleylancer
Post by Gleylancer »
Use a security device for security, not a switch.
thermseeker
Thank you Silvio.
Return to “OmniSwitch 6900”
