How to set it up BPDU GUARD
ghdgusrl7
Post by ghdgusrl7 »
hi :)
I want to set up BPDU Guard, what are the commands?
And if I set BPDU Guard, is it right that the port where the BPDU comes up will be shut down?
After setting the BPDU Guard, please give me a check command
please
Re: How to set it up BPDU GUARD
look into the guide for the feature userports with bpdu shutdown.
BR Silvio
