dhcp client - 2360
kdh
dhcp client - 2360
Post by kdh »
I've set up the dhcp client on a 2360 switch so it would get a "backup" ip config if moved to another site (with a different ip range)
Thing is it gets its ip ONCE and uses it as if it was a fixed ip...
Switch never requests another ip ever... (start, "uplink" disconnected/reconnected) either keeps the same, or 0.0.0.0 "DOWN" if a duplicate ip is found on the network.
Any idea how to make it work like it's supposed to (ie like any other device ever created) ?
Thanks in advance !
Gleylancer
Re: dhcp client - 2360
Post by Gleylancer »
What do you mean "like any other device ever created"? This is a switch. The DHCP service has no awareness about a shutdown or disconnect of any port - and this is correct behavior. Other vendors do it the same way, Aginode for example.
kdh
Post by kdh »
Gleylancer wrote: 04 Feb 2024 09:32 The DHCP service has no awareness about a shutdown or disconnect of any port - and this is correct behavior.
Sure, but you'd expect it to request a new ip/lease when you remove the power cable, move it to another location (with a different ip range), and replug it
Return to “OmniSwitch 2260 / 2360”
