hello so since this morning we have a UA32 card which some items do not work anymore. i did a rstcpl on it but nothing we have two UA32 card we replaced it same problem i show you the captures
| 0 | 0 | eUA32|---------- |ONLY OPS FILE | BAD PCMS CODE |
| 0 | 1 | NPRAE|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 2 | eZ32|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 3 | INTIP3A| INT-IP3 | IN SERVICE | BAD PCMS CODE |
| 0 | 4 | PRA2|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 5 | GPA2|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 6 | CPU7_STEP2|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 7 | IO2N|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 8 | NDDI2|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 9 | PRA2|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 10 | UA32|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 11 | eUA32|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 12 | NDDI2|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 13 | MMSFD|---------- |ONLY MAO FILE | BAD PCMS CODE |
| 0 | 14 | UA32|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 15 | UA32|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 16 | PCM2|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 17 | VPU5|---------- |ONLY OPS FILE | BAD PCMS CODE |
| 0 | 18 | NDDI|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 19 | NPRAE|---------- |ONLY OPS FILE | BAD PCMS CODE |
| 0 | 20 | CPU7_STEP2|---------- | OUT OF SERV | BAD PCMS CODE |
| 0 | 21 | IO2N|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 22 | eZ32|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 23 | PCM2|---------- | REG NOT INIT | BAD PCMS CODE |
| 0 | 24 | INTOF_A|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 25 | PCM2|---------- |ONLY OPS FILE | BAD PCMS CODE |
| 0 | 26 | eUA32|---------- | IN SERVICE | BAD PCMS CODE |
| 0 | 27 | UA32|---------- | IN SERVICE | 3BA53050ABBC01 |
I wonder if it's normal for it to display numbers instead of "BAD PCMS CODE". After changing the card, the same stations located in the same place remain out. I did a rstcpl just after inserting the new card, but nothing happened.
when i do a termstat d n° station option 5, the status of the station changes from "A . . . . U . . . . ." to "A . . . . . . . . . "the letter U disappears anyone have an idea thank you in advance
|Coupler: 0 27 Logic type: CPL_UA Board:UA32 State: IN SERVICE |
| Cry:Cpl:ac:term| neqt | typ term | dir nb | Out of service cause |
| 0 27 0 0 | 00477 | 4019 | 7945 | A . . . . U . . . . |
| 0 27 0 1 | 00478 | T_RESU | | A . I . . U . . . . |
| 0 27 0 2 | 00479 | 4039 | 7540 | A . . . . U . . . . |
| 0 27 0 3 | 00480 | 4029 | 7533 | A . . . . U . . . . |
| 0 27 0 4 | 00481 | 4029 | 7500 | A . . . . . . . . . |
| 0 27 0 5 | 00482 | 4029 | 7866 | A . . . . . . . . . |
| 0 27 0 6 | 00483 | 4029 | 7503 | A . . . . U . . . . |
| 0 27 0 7 | 00484 | 4029 | 7538 | A . . . . U . . . . |
| 0 27 0 8 | 00485 | 4029 | 7307 | A . . . . U . . . . |
| 0 27 0 9 | 00486 | 4039 | 7316 | A . . . . U . . . . |
| 0 27 0 10 | 00487 | 4029 | 7416 | . . . . . . . . . . |
| 0 27 0 11 | 00488 | 4029 | 7272 | A . . . . . . . . . |
| 0 27 0 12 | 00489 | 4029 | 7253 | . . . . . . . . . . |
| 0 27 0 13 | 00490 | 4039 | 7800 | . . . . . . . . . . |
| 0 27 0 14 | 00491 | 4029 | 7904 | . . . . . . . . . . |
| 0 27 0 15 | 00492 | 4020(LE_3G | 7006 | . . . . . . . . . . |
| 0 27 0 16 | 00493 | 4039 | 7847 | . . . . . . . . . . |
| 0 27 0 17 | 00494 | 4029 | 7418 | . . . . . . . . . . |
| 0 27 0 18 | 00495 | 4039 | 7815 | . . . . . . . . . . |
| 0 27 0 19 | 00496 | 4029 | 7140 | . . . . . . . . . . |
| 0 27 0 20 | 00497 | 4039 | 7320 | . . . . . . . . . . |
| 0 27 0 21 | 00498 | 4035(MR2_3 | 7530 | . . . . . . . . . . |
| 0 27 0 22 | 00499 | 4029 | 7321 | . . . . . . . . . . |
| 0 27 0 23 | 00500 | 4029 | 7423 | . . . . . . . . . . |
| 0 27 0 24 | 00501 | 4035(MR2_3 | 7853 | A . . . . U . . . . |
| 0 27 0 25 | 00502 | 4029 | 7833 | A . . . . U . . . . |
| 0 27 0 26 | 00503 | 4029 | 7325 | A . . . . U . . . . |
| 0 27 0 27 | 00504 | 4029 | 7515 | A . . . . U . . . . |
| 0 27 0 28 | 00505 | 4029 | 7518 | . . . . . . . . . . |
| 0 27 0 29 | 00506 | 4039 | 7905 | . . . . . . . . . . |
| 0 27 0 30 | 00507 | 4029 | 7322 | A . . . . U . . . . |
| 0 27 0 31 | 00508 | 4039 | 7907 | A . . . . U . . . . |
| (A: att_mserv|S: hs smooth), C: hs_defich, I: hs_isolauto, X: hs_isolman|
| T: hs_terdef U: hs_usdef, P: hs_errparite, B: hs_bascul, Y: hs_cristisol|
| Nombre total de terminaux hors service : 16 |
| Nombre total de terminaux en service : 15 |
two UA32 boards defective
Re: two UA32 boards defective
OK after terminal rest and you got A put a terminal in that equip fe 0 27 0 11 and wait the terminal ll be in service
A = attente mise en service : branchez le terminal; si toujours hs alors verifier la ligne
bad pcm code dont worry about that
Still the same problem! the lines are good too, I don't understand anything, I've tried deleting and recreating the number on the same address, nothing the same, but when I connect it to another digital card, the set works.
Is it normal that after replacing the UA card, the same stations at the same address remain out of service?
Run incvisu and see what's the related incident
