Hi all ,
OTMS 2.6.1
When my users go to https://xxx/MyMessaging , the web based voicemail displays "No element" while user have voicemails.
Anyone know the work around on this one?
Web based voicemail displays "No element"
- frank
Re: Web based voicemail displays "No element"
Check tomcat and chameleon services.
Certificates are ok?
You can also try to restart the iced in out of working hours.
If does not solve, better take some logs, using dla tool.
- frank
Tomcat and chameleon are ok.
All services are up and running.
I rebooted the server, same issue.
I m thinking I need to take logs now and open a ticket...
Hi Frank,
It is local storage or unified messaging?
- frank
Fixed the issue with upgrade from MD1 to MD5...
