Displayed name
Displayed name
Greetings all,
Anyone knows how to changed the displayed name when we call an oxe user ?
I have someone where I want to display something else than last_name first_name.
I changed the "Displayed name" option under the user, but it does not change anything when I call.
I was pretty sure I used this in the past successfully. It's a system I am taking over. Is there an option somewhere to disable the "Displayed name" ..?
Re: Displayed name
If i'm not wrong it's under system(installation) but it may affect all the users
Re: Displayed name
I searched under System , System / Other system parameters , System / Other system parameters / (Local features | System Parameters | Spec. customer) without success...
Re: Displayed name
sorry for the confusion that was for directory number
may be you have managed something in the abbreviated number for that user to get it
Displayed Name
This attribute enables you to have a personnalised name for the display (16 characters max.) for cases where the directory name/first directory name does not fit on the display.
Re: Displayed name
Nop. Tried that also..
My only way is to switch last_name <--> first_name , but I dont want to do that....
sadim
Re: Displayed name
Post by sadim »
For tne moment i can only say by memory because my PC is off, but it should be related to utf-8, so you need to go to the Noe cos and devalidade something like compatibility.
Hope it helped even without providing the full path
oldboy
Re: Displayed name
Post by oldboy »
Frank all you need to do is populate UTF-8 under the user to what ever you want and it replaces the dir name and first name
Re: Displayed name
oldboy wrote: 10 Sep 2023 17:11 Frank all you need to do is populate UTF-8 under the user to what ever you want and it replaces the dir name and first name
Will try that.
What is the "DISPLAYED NAME" used for then?
I thought this worked in the past..
sadim
Re: Displayed name
Post by sadim »
It depends if the calling set supports on not utf-8.
NOE sets supports utf-8
Return to “Users”
