SNGREP - INTRO
SIP Flow message viewer from the console
Locked
SNGREP - INTRO
sngrep is by far one of the best tool the OXE should have, but never had.
It's a live SIP Flow viewer, right from the console.
Simply copy the sngrep.tar.gz archive on the oxe.
Unarchive the file using the command tar -zxvf ./sngrep.tar.gz
With the root user, change the owner and right to the file with the command chown root.root ./sngrep ; chmod 755 ./sngrep
Finally, as root, launch the command ./sngrep , et voila!
If you have any question, open a new topic in this subsection.
NOTE:
- This post contain a PGP Signature file (sngrep.tar.gz.tar.gz)
-> You can uncompress it, and validate the authenticity of the sngrep archive (sngrep.tar.gz) against my PGP Signature (frank@hermes42.com)
-> I guaranty that there is no spyware or virus in this binary.
The MD5 are
MD5 (sngrep.tar.gz) = 00948e8d270a5012fcf80c720d1316e5
MD5 (sngrep.tar.gz.sig) = bd455df708513a7d00a35041615ce286
MD5 (sngrep.tar.gz.tar.gz) = 98015fce81df771cf13934e202bbd3ef
After you copied the files in your OXE, here is how you can validate the md5 if you don't know how to use PGP.
(E)cpua> md5sum sngrep*
00948e8d270a5012fcf80c720d1316e5  sngrep.tar.gz
bd455df708513a7d00a35041615ce286  sngrep.tar.gz.sig
98015fce81df771cf13934e202bbd3ef  sngrep.tar.gz.tar.gz
Locked
Return to “sngrep”
